Golden_HVAC
Jan 02, 2015Explorer
You can run your generator for a few of hours on one gallon of gasoline. The V10 will use a couple of gallons per hour, and running at less than 1,800 RPM, then there is not a lot of oil volume being pumped by the engine, and upper valve area, and cam might not get enough splash lubrication, so that can cause problems.
It is better not to idle a larger engine.
And the "130" amp alternator is 'rated' in a LAB, not on a real engine in the real world, and only while it is cold. Once over 130F (such as under the hood of any vehicle) the rating goes way down, and at idle, the rating falls off to only about 85 amps.
So expect the engine alternator to put out say 100 - 110 amps at 2,000+ RPM, and at normal under the hood temperatures.
What your battery can accept is another matter. Your charger might be rated at say 45 amps, or even 55 or 60 amps. Probably only putting out around 15 amps into the 85 amp hour battery. So all that gas is mostly wasted to charge the battery. If you double the amp hour rating of your battery bank, then you can put back twice as many amp hours per hour of generator run time.
So even with my 4 golf cart batteries, and my 70 amp inverter/charger, hooked up with huge battery cables to the golf cart batteries, my charger is not putting out anything near 50 amps for more than a couple of minutes.
I have a 'E-Meter' and it carefully measures the amps going into and out of my battery bank. So one morning I was at -120 amp hours (watching a lot of TV) and ran the generator at breakfast. I was charging at around 45 amps for the first 10 minutes. After breakfast, it was less than 35 amps (so 30 minutes of charging total time) and I shut off the charger. I was only putting back about 35X14 = 250 watts. Hardly worth the noise and expense to run a 4,000 watt generator.
I let my 400 watt solar system finish the charge, at around 20 - 22 amps per hour until near sunset, when it stops charging (normally full by 3 or 4PM).
You will be much better off charging the battery twice a day. As you have already found out, you get the most amperage from the first hour of charging. Second hour charging is much slower.
Your battery will be depleted by 35 amp hours just to run the CO meter, refrigerator and propane leak detector for 24 hours. Run the 6.5 amp furnace fan for 5 hours, and take away another 32.5 AH. It will take about 90 amp hours to replace that 70 used power. So three times running the generator for about 1.5 hours each day should do the trick.
I would still recommend another battery.
Also a Olympic Catalytic heater. It has a pad to prevent formation of Carbon Monoxide, a killer by-product of burning propane or natural gas (or gas or diesel). You will still need to leave a roof vent open, and window slightly cracked open. Just like while cooking. I have a 6,000 Btu model and it keeps my 30' Bounder with good insulation warm at 30F outside air temps. Below 30, and I still need to run the furnace once in a while to bring that warm air into the basement, and circulate the warm air around the RV!
I have my heater hooked up to a quick disconnect, under my stove, where I installed a 3/8" flare Tee.
Good luck!
Fred.
Good luck!
Fred.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
