RJsfishin wrote:
No. depending on converter output and alternator output.
My 140 amp alternator will charge much faster than my PD 45 amp converter.
And 2 different charging sources will usually fight each other. The one w/ the highest voltage will do most all the charging
And my 80 PD-80 amp is faster than my alternator at charging house batteries.
So what is the moral of this...
A joke
The story goes researchers ask a bunch of men "Boxers or Briefs"
The young men said "Boxers"
The middle aged "Briefs"
And the old fogies "Depends"
It all depends on the size of the alternator. The size of the connecting wires, and their length, and the size of the converter and again the wires and length.
So the bottom line is this.
Using a CLAMP ON DC-ammeter Like a Crafstman 82369 or another like meter measure the current on .. likely the Negative lead with Generator running. Then with main engine running.
And finally with BOTH running.
https://www.amazon.com/Craftsman-Digital-400A-Clamp-Ammeter/dp/B003TXUZDM/ref=cm_cr_arp_d_product_top?ie=UTF8
