doughere
Nov 04, 2013Explorer
I have a wall mounted Volt and Amp meter installed, so I have a pretty good idea of what's going on.
With 120 watts through a controller, and a 100 watt panel un-controlled my 2 GC's voltage only gets into the 15 volt range when battery is close to 100% and un-controlled panel is facing bright direct sun. Unless you were close to full, you aren't going to run into problems. If you were to leave for a day, you might briefly over-charge; the sun will only be directly on panel for a short time. I wouldn't worry about it.
I have a controller on the 2 60 watt panels as they are fixed on the trailer. The 100 watt panel (not controlled) is portable, and used as needed.
Regards,
Doug
Regards,
Doug
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
