pianotuna
Nov 04, 2013Nomad III
Hi,
The foil at a proper angle would. In the far north panels are installed vertically so that sunlight will bounce off snow cover.
NinerBikes wrote:
OK, next dumb question... If you put a pure white towel, or aluminum foil in front of a tilted panel, will it generate more current when the sun is lower on the horizon, due to more energy reflected into the solar panel?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
