MNtundraRet
Jun 19, 2013Navigator
Answer is: It depends.
If the built-in charger is multi-stage (can reach 14.4+ volts for high amp-rate charging), allowing it to go alone at first, per Mex, is most likely best. When the first charger falls back to 13.7 volts, then add the portable charger. Both will most likely keep charging at 13.7 volts (absorption mode) until one senses "full" charge ahead of the other.
If you have a "clamp-on" multi-meter, you could easily check the AMPs being output by each charger and add the total. Use the clamp on the POS(+) cable off each charger. If the amps total more than the best charger alone you are gaining ground.
On the other hand if you start with both chargers, the multi-stage charge may either drop out of "bulk mode" early, or never get into it. This way you may fall behind.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
