wa8yxm
Jun 19, 2013Explorer III
If you have two chargers hooked up (Which reminds me... I do just now) then one of 3 things will happen.
1: one will charge the other will relax
2: Both will charge
3: Both will charge causing the batteries to be damaged by the too fast charge
odds are both will charge, but at a reduced rate. so as to not damage the batteries.
DEPENDING on what converter you have in the RV and where it's located.. You might be better off with just one of them running.. But that said.
your plan should work.
2: Both will charge
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
