bought a ramp for a scooter to put on the back of our trailer when we travel. but when i insert the 2in square tube into the hitch receiver it wobbles back and forth. is there any type of shim or othe...
Insert the offending receiver into the hitch, using the smallest opening you can cut into the tip of a tube of silicone sealant and squeeze a tiny bead in between the top of the receiver and the top of hitch.
After it cures you will have the quietest ride ever. If you need to remove it just pull the receiver out and peek off the little strip of silicone.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
