joelyn's avatar
joelyn
Reciever wobbles
bought a ramp for a scooter to put on the back of our trailer when we travel. but when i insert the 2in square tube into the hitch receiver it wobbles back and forth. is there any type of shim or other way that people use to keep it straight? thanks
  • JaxDad's avatar
    JaxDad
    Explorer III
    Insert the offending receiver into the hitch, using the smallest opening you can cut into the tip of a tube of silicone sealant and squeeze a tiny bead in between the top of the receiver and the top of hitch.
    After it cures you will have the quietest ride ever. If you need to remove it just pull the receiver out and peek off the little strip of silicone.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    THe short answer is yes there is a solution to your problem
    I have an older version of this device, they have improved it over the 13 years I've had mine
    Blue Ox Hitch Immobilizer
    It works well, and does exactly what you want
    NOTE: I also have another company's "Knock off" product.. ****.
    What is the difference. The blue ox unit all welds or joints are under COMPRESSION load. only the bolts are "Stretched" The knock off had welds that were under "Streatch" load and promptly broke.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
