jhilley
Jun 12, 2014Explorer
daamac wrote:
Consider the amperage capability of the 12 volt outlet and wiring and fuses. For example, for a 300 watt inverter, you'll need to have at least 25 amps available at the 12 volt outlet (12 x 25 = 300).
This is true. The 180 watt will take 15 amps at full power. 125 watts of use would be 10 amps. Make sure that your cigarette lighter socket is fused for what you need.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
