trailertraveler's avatar
Aug 13, 2017
Recommendations for Low Battery Disconnect
I have a Samlex 300 watt (500 watt peak) inverter that I use to power a TV and satellite receiver that draw 100 watts based on the labels on the devices. The inverter shutoff is at 10.5 volts which is essentially zero state of charge for the batteries. We mostly watch TV at night, so the solar panels are not in play (during the day they will run the TV/satellite without draining the batteries). I would like to have the inverter shutdown at 50% discharge or a little less in the event that I fall asleep and don't shut the TV/satellite off. I am interested in what others may have done to solve this issue.
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,333 PostsLatest Activity: Nov 06, 2025
