StirCrazy
Oct 24, 2023Moderator
unless you are planning to install a whole eco system and spend lots of money stay away from Victron. If all you want to do is install your free panels and keep the price down, look at Renogy. You do want an MPPT set up. If you wire your panels in series, you will up the voltage going into the controller but keep the amps where they are at so you can get away with say a 40-amp MPPT controller from renogy as it will take a 100v input. This is what I use in my camper
