Boomerweps
Oct 28, 2023Explorer
Several battery disconnects are set up with a battery 1, 2, 1+2, and off positions. If used to seperate battery banks, a pre controller panel disconnect switch should be added to use while shifting battery banks.
My hillbilly engineering degree method is that I have an SAE/Zamp style side connection from the panels and another similar inside from that jack that I can easily disconnect. The interior one is handy if I want to connect the stand alone charger. Switches are great but unplugging works just as easy.
