MrWizard
Oct 29, 2023Moderator
Suggestion
Get a DC marine type circuit breaker, 50 amp is good 100 amp would be better, place in circuit between the panels and the solar charger controller, then whenever you need to switch battery Banks, or any kind of battery service , you can easily open the circuit , safely disconnecting the panels, preventing damage to the controller, I also installed a DC breaker between my batteries and my 2000w psw inverter, that one is rated at 250 amps
