donn0128
Jan 29, 2014Explorer II
Welcome,
Please be aware that there are many different boards on this forum, You are asking in FORUM technical support. I have asked the moderator to move it to the correct location for you.
Now to answer the question. 200 watts is a good start. There is no way you can pack enough batteries on a trailer to run an AC unit or any other high amperage draw appliance for that matter. Just does not work.
There are tons of posts on solar on the forums. I suggest you start by searching the 12volt side of life on the internet, then using the search function above put in words like solar and start reading.
Having RV issues? Connect with others who have been in your shoes.24,377 PostsLatest Activity: Apr 11, 2026
