time2roll
Jan 29, 2014Nomad
You will need 2000+ watts solar to run the air conditioner. Lots of battery too as the sun goes down. Maybe you meant power small A/C items like a laptop, much easier.
Not sure what a uWave is. Microwave needs an 1800+ watt inverter to run off the battery(s) for a few minutes. The 200w solar would then be recharging all day.
Here are some solar installs to look at:
Forum Members Solar Installations With Pics
12 Volt Side of Life
Usually the wire goes down the fridge vent or waste tank vent. Controller should be close to the battery for best results.
Having RV issues? Connect with others who have been in your shoes.24,377 PostsLatest Activity: Apr 11, 2026
