westend
Jan 29, 2014Explorer
Gonzo42 wrote:It's usually more efficient to connect any number of modules through the same charge controller, distributing the power through mechanical termination. What I'm meaning is that you don't need to dedicate one module to the house batteries and one to the chassis battery.
Yes, uWave means microwave. In engineering jargon the omicron (u) meens micro. I was concerned 200W would be insufficient for the rooftop A/C. Thanx for confirming it. Will eventually opt for portable generator, then. Still want solar to keep batteries topped off. Might go for two smaller (100W?), one for starting battery, one for house.
Schedule/location of wiring is usually not an issue. Look through the link posted of member installs for ideas. The best location for the charge controller is adjacent to the batteries.
Having RV issues? Connect with others who have been in your shoes.24,377 PostsLatest Activity: Apr 11, 2026
