EsoxLucius
Jan 30, 2014Explorer
Gonzo42 wrote:If you just put up a simple solar array in parallel the use of the Blue Sky Energy Solar Boost 2512iX-HV solar controller allows for a 2 amp chassis battery charger when the coach batteries are in absorption or float. Also, if you add the Blue Sky Energy IPN-ProRemote and shunt, besides full control of the SB2512iX-HV, you also have a battery monitor. Nice solution.
Yes, uWave means microwave. In engineering jargon the omicron (u) meens micro. I was concerned 200W would be insufficient for the rooftop A/C. Thanx for confirming it. Will eventually opt for portable generator, then. Still want solar to keep batteries topped off. Might go for two smaller (100W?), one for starting battery, one for house.
Having RV issues? Connect with others who have been in your shoes.24,377 PostsLatest Activity: Apr 11, 2026
