boogie_4wheel
Jan 03, 2017Explorer
I used the Easy-Heat heat tape on my fresh water hose for 2yrs. I bought it a little long. I started the tape about a foot from the trailer inlet (the thermostat end), went up to the inlet on the trailer, then back to the spigot, wrapping the valve and spigot. I attached it with electrical tape about every foot. I then covered the hose with 1 size too large pipe insulation (to fit the heat tape and not leave a gap at the slit). Some more wraps on the foam pipe insulation to keep it from coming undone.
I then wrapped the spigot with fiberglass insulation, then 2 heavy duty trash bags.
I survived 2 winters that experienced -20*F regularly. It was cheap and effective!
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
