kbehrent
Aug 10, 2015Explorer
BFL13 wrote:
Not answering all, but do note your four 6s are probably in series/ parallel for 12v and 464AH.
IMO set your capacity at that 464. Your charger can do ISTR 100amps if not limited by another setting, so unless you are short of 120v amps when plugged in or on generator, use it all and get the 100 amps going at the battery bank. (That is not too much on 464AH)
Nice catch on the capacity, you are correct that they are in series/parallel. Not sure now whether to set the Battery Capacity on the RC7 to 500 or Auto. Not sure how good it is on detecting capacity correctly.
