klutchdust's avatar
klutchdust
Explorer II
Oct 14, 2023
Red light on > Atwood water heater
dual water heater, gas/electric. Noticed the red light on the switch has been coming on. Been running generator as I dry camp at the race track long enough to cool the inside or micro something. The electric switch has been off. I turned the gas switch off this morning as the light was on and when I switched it back on I heard the heater fire up.
Plenty of hot water.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    There may be two lights.. You mentioned "The red light on the switch"
    On my water heater the switch lit up red if turned on.. That way you knew if Gas or Electric was on) then there was a FAULT light (All red)
    The RED fault light... Indicates one of two conditions.
    ONE Over temp (Emergency Cut Out) sensor activated (See notes) That's on any mode.
    Two Flame not detected after 3 tries to light (Gas only)
    NOTES. The ECO is a disc thermostat I think it's like 190 or 200 degrees.
    But the wires going to it can "Tarnish" and lose connection.. So it might be over temp.. Or broken wire, or bad connection Or control board failure or _________ (Fill in the blank).
  • The Red Light is letting you know that at some time the Water heater DID NOT light when called for. Once that happens, the system is locked out and you must turn it OFF like you did, and restart. Doug
Having RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
