beautifuljess's avatar
Jul 07, 2017
red, white, green wires where do they go? and to what?
generator was making a noise, shut it off, when I went to go turn it back on it blew the 5 amp fuse, and has continued to blow fuses since, got a new marine battery but still blowing fuses and the generator wont stay going. then went to store and hurd a noise from rear tires and found the red,white,green wired wrapped around my wheels. refridgerater don't work now and generator still popping fuses and don't know where or what the wires go to?? any help
  • sounds like control wires ?
    does the inside generator start switch work ?
    or are you starting it from outside at the generator ?
    is the fridge on that side of the RV, how close to the rear axle ? directly above it ?
  • depending on how large the wires are, they could be green = ground white =neutral and red = 120 volts from generator. do the wires come from the generator? or do they come from under the house?
Having RV issues? Connect with others who have been in your shoes.24,245 PostsLatest Activity: May 11, 2025
