Teleman
Jan 20, 2022Explorer
All cabling is well within spec. The starting and house batteries are within two feet of each other and the charger is next to the house battery. Replacing the tripping breaker with a Blue Sea unit solved the problem. Input current to the Redarc gets as high as 54 amps with the ignition on without starting the motor. Settles to around 45 with the motor running. Output current stays about 43 amps when driving and climbs to about 48-49 at idle. This seems somewhat out of spec but it's certainly acceptable to me in terms of performance.
