Teleman
Jan 20, 2022Explorer
wa8yxm wrote:
Ok DC/DC chargers are voltage converters. they work one of two ways (Buck only or Buck/Boost) if boosting the amps in go up as the volts out go up.
And they also draw "overhead" power.
How to limit the current so the breaker does not pop I do not know other than a longer wire.. I'd not recommend a smaller wire, between the unit and the battery Make sure the wire can haul the full 40 (in fact 50 to be safe) amps but lengthen it so the resistance limits the current DO NOT COIL IT
Replacing the cheap breaker with a quality Blue Sea unit did the trick.
