Teleman
Jan 20, 2022Explorer
otrfun wrote:Teleman wrote:Any particular reason you would allow your dc to dc charger to be on-line when the alternator is off-line? Most use a battery isolator or trigger wire (found on most dc to dc chargers) to prevent the dc to dc charger from inadvertently discharging the starter/TV battery when the alternator is off-line for any reason.
. . . Input current to the Redarc gets as high as 54 amps with the ignition on without starting the motor . . .Teleman wrote:Are you saying the output or input current climbs to 48-49a at idle?
Output current stays about 43 amps when driving and climbs to about 48-49 at idle.
If the output/charge current climbs to 48-49a at idle, I'd have to agree, it's definitely out-of-spec. How high did the input current go?
If you're referencing input current to the dc to dc charger, then 48-49a would seem perfectly normal with the alternator operating less efficiently at idle (higher voltage drop forces higher current).
I only turned the ignition on to measure the current briefly out of curiosity before I started the motor. The charger activates with a signal from the ignition. The output current is about 43A at higher rpms and 48 at idle like I said.
