otrfun
Jan 22, 2022Explorer II
S Davis wrote:Our Renogy draws max current almost immediately.Teleman wrote:Delay is about 30 seconds and then it ramps up the amps over about another 30 seconds.otrfun wrote:As I recall there is a delay from when the ignition is activated to when the charger passes current.
Forgot to mention this previously. Something that needs to considered when electing to turn on a dc to dc charger based on ignition voltage (vs. alternator output voltage) is potentially reduced current to the starter while starting the engine. As soon as the ignition is turned on, a 40a dc to dc charger could be drawing as much as 60a from the battery. On some vehicles that 60a reduction could impact starter performance---especially in extreme cold/hot weather conditions.
IMO alternator voltage should be the preferred turn-on method for any dc to dc charger. Using this method, the dc to dc charger cannot activate unless the alternator is online, providing charge voltage/current. This makes it virtually impossible for the dc to dc charger to inadvertently discharge the battery---even if you accidently left the ignition on (without the engine running) for several minutes, or much longer. For me, it's one less thing to worry about---a good thing.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
