StirCrazy
Jan 23, 2022Moderator
otrfun wrote:
IMO alternator voltage should be the preferred turn-on method for any dc to dc charger. Using this method, the dc to dc charger cannot activate unless the alternator is online, providing charge voltage/current. This makes it virtually impossible for the dc to dc charger to inadvertently discharge the battery---even if you accidently left the ignition on (without the engine running) for several minutes, or much longer. For me, it's one less thing to worry about---a good thing.
I am installing mine on a ignition controled Upfitter switch. this way it will only go when the key is on AND the switch is turned on. that way if my batteries are close enough to full the solar can handle it I can leave it off, but if I had a few days of bad weather I can switch it on to give the solar a hand. If I forget its on and I turn the truck off it will shut off.
Steve
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
