vacuumbed's avatar
vacuumbed
Reducing 12 VDC to 9 VDC
Hello all,
I bought this neat bath vanity mirror that has LED lights. It is made for residential homes and uses 110V with a transformer plug, of course.
The transformer says the output is 9 volts and 1 amp.
I would like to wire this to my RV. Is there a resistor of some kind that can accomplish this for me?
Thanks in advance.
  • You can buy a adapter at Radio Shack with a 12 volt plug into a cigarette lighter, and 6, 9 and 12 volt output - adjustable. Check the amp rating, they have some only rated at 300 ma, while other models are rated over 1 amp.
    Basically they use a internal voltage reducer. . .
    Good luck,
    Fred.
  • You would have to build a regulator circuit taking the 12 volts and regulating it to 9 volts like a lm 39 series regulator or the adjustable regulator circuit.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
