dougrainer
Jul 11, 2018Nomad
pnichols wrote:dougrainer wrote:
DO NOT allow the end to lay in the drain cup. lift it up a 1/2 inch and have it dangle just above the drain cup. That will allow the check valve to do its job and not get clogged up.
How does allowing the end to lay in the drain cup prevent the one-way check valve from letting water drain out of the line into the drain cup?
WHAT I am saying, is, to PREVENT the check valve from getting gummed up and NOT working, do not lay it in the drain cup. I did not say it would prevent the drain check valve from working. I guess you are just ONE OF THOSE PEOPLE, has to argue everything:h Doug
