Big_Katuna's avatar
Big_Katuna
Explorer II
Jul 10, 2018
Reefer drain hose thingy ma bob
Had water on the floor under the fridge. Went outside to look at the drain line, cut the end off and a lot of war we came out.
I had heard of the little filter-plug thing clogging and intend to clean it and put it back
But I have to ask;
What does it do and what problem does it solve?
  • wnjj's avatar
    wnjj
    Explorer II
    enblethen wrote:
    You can also re-route the tube to put a small "P" trap in the line to prevent critters from entering.
    What about when it dries out during the off season?
  • Reminds me that I should do something with my furnace.
  • I bought one of those plastic mesh-like dish scrubbers for a dollar or so, cut off a small piece, and pushed it up into the tube.
  • SAR Tracker wrote:
    keeps bugs out of the tube. Yellow Jackets in particular.
    Or, you can get a new one here.....
    $11.00???
    ROFL!
    When I bought the RV new I added screens to all vents as Mud Daubers are a scourge in Florida.
    If I can clean this one enough I’ll put it back on or add a screen.
    Thanks all.
  • You can also re-route the tube to put a small "P" trap in the line to prevent critters from entering.
  • Keeps bugs from crawling up into the fridge. Keeps wasps from building mud nests inside and stopping it up. bugs like to get the water on the inside. Clean it, and put it back. Alternate is to take a bit of screen mesh and cover the opening, rubber band or tiewrap to hold in place. The filter plug is the best solution, just check and clean occasionally.
Having RV issues? Connect with others who have been in your shoes.24,333 PostsLatest Activity: Nov 06, 2025
