Horizon170's avatar
Horizon170
Refer door ventilation
My used RV didn't come with the hold door open plastic thingy so I made mine.
Three wall anchors, three lock nuts, plastic cap to cover end threads and a rather strong magnet from a "Shake'em Flashlight.
ALSO-----does the atwood water heater require a anode screwed into the drain port? Mine doesn't have one but I have a left over spare from another RV.
Picture 3 shows the DIY adapter I made for blowing out water lines.
">In position
">As built
">Adapter to blow out water lines
  • I am pretty sure the Atwood water heaters do not use an anode rod. Mine has an electric heating rod that goes through the drain hole.
  • fj12ryder wrote:
    Shoot, I just drape a dry dishcloth so the doors can't close. Very low tech, but works a champ.
    I don't want them flying around while I'm driving.
    Marvin
  • Shoot, I just drape a dry dishcloth so the doors can't close. Very low tech, but works a champ.
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Nov 11, 2025
