Ivylog
Aug 06, 2015Explorer III
OP, you do not say what refer you have now. Depending on the sizes, getting the units out/in can be the biggest challenge. Finding a home refer the same size is not likely so some modifications of the cabinet area may be required. I recently replaced my NoCold 1200 myself here.
Another issue is how are you going to power it when not on shore power... these are campers so often off the grid. If you boondock often then extra batteries will be necessary plus a inverter to power it.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
