MEXICOWANDERER
May 26, 2016Explorer
AFTER 300+ BOTTLES I ARE EXPERIENCED
I filled some 150 bottles on a popular Mexican beach back in the eighties. They squawked about the four dollar charge until they drove 50-miles to discover the hardware store had long since run out of ten dollar bottles.
- You need an accurate scale with TARE setting PERIOD
- The POT is set on a table upside down to make only liquid available
- Tweak the bottle valve to flush most of the air out of the hose
- FREEZE the empty bottles or spend the rest of your life waiting for them to fill
- Screw bottle onto the connector pigtail
- Set scale tare to zero
- Carefully open valve on pot and watch scale go to 14 oz, then tweak valve shut
- Did the "over-run" fill the bottle to 16oz. NET?
- Overages must be bled down to 16 oz. NET
- Dunk filled bottles into a pail of water
- See bubbles?
- If there are bubbles, use ice-pick to bleed off a spootch of gas, then re-test
- Leaking bottles are a bomb
- Absolutely zero rust permitted on threads, fill port on anywhere on bottle
- Vaseline petroleum jelly smeared lightly onto bottle threads will reduce corrosion in storage
- Tilt pot upright to allow liquid to fall to bottom
- Liquid LPG has every ability to cause frostbite
- Have a fire extinguisher handy
- Threaten the life of any smoker who may approach.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
