fla-gypsy
May 27, 2016Explorer
nickthehunter wrote:fla-gypsy wrote:You should be aware that the explosive potential of a 20 lbs cylinder under pressure is about 20 times greater than that of a 1 lbs cylinder.
You should be aware of the explosive potential of 1 lb of LP under pressure. The videos are out there.
And a 30lb cylinder etc. etc. This I know, but the OP seemed very unsure of how the process works for refilling a cylinder designed to not be refilled. I'm in no position to tell anyone not to do something unless it is something I have expert knowledge of. I just wanted the OP to understand what could happen. These are key to reducing risk and avoiding hazards both of which are pillars of good safety practices which I am an expert on. Any other safety professionals want to chime in?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
