SaltiDawg
May 27, 2016Explorer
westend wrote:
I would bet a doughnut that the explosive energy of a 20 lb cylinder is more than 20X greater than a 1 lb cylinder. Construction is different for higher operating pressures and the explosive result of the gas igniting wouldn't be linear as to weight difference.
So, two cylinders side by side. One 1lb and one 20lb.
Both at 80 degrees Fahrenheit. Which cylinder has the higher pressure?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 13, 2026
