westend
May 28, 2016Explorer
2oldman wrote:That's not the answer I get but is somewhat immaterial. If 8 million gallons of propane starts igniting, I don't want to be anywhere close.westend wrote:Propane at 4.25lb/gal, that's 988 tons, give a ton or two.
Two 100,000 bbl tanks = 200,000 bbls. 8,400,000 gals.
I dunno the comparative energy in a pound of propane vs. pound of TNT, but there it is. That's a long way from 15,000 tons.
Before the owners installed a cooling/pressurizing plant onboard, there was a lot of "white knuckling" watching cargo temps and tank pressures. The tanks were set up with automatic relief valves, a set of ten or so 6" pipes that would evacuate pressure when it reached a certain threshold. The cloud of propane that came out of those suckers was a thing to behold, massive.
At certain times, when pressures were close to the relief threshold, we would hang a 10" cargo hose over the side and relieve some pressure. It was a better situation than trying to steer away from that cloud of gas.
After the cooling array was installed, we didn't have any of those discharge issues. I also learned that a dozen cases of beer could be chilled in a few minutes by discharging through the 3/4" inspection/sampling valve. Just had to keep the deckhands away with their chipping hammers until the propane "iceberg" melted away.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
