Ok, first, keep in mind that I've had this a few years and everything has worked properly before. That being said, here's the problem: I have one of the Dometic 4 door refrigerators. The other day ...
Fridge worked fine until self inflicted battery issues and now you question fridge??
Get battery fully charged----LOAD tested before looking at fridge.
Need good strong 12V DC whether using electric or propane heat source. When hooked up to shore power converter handled that. When disconnected from shore trailer battery didn't do so well....truck charge line is OK for maintaining a charge on a GOOD battery. Not so on a bad battery
