Dutch_12078
Aug 16, 2019Explorer III
kioticoachman wrote:Dutch_12078 wrote:
Check the area behind and just above the engine battery for the low pressure A/C port. Some years and models have it there. Another spot sometimes used requires pulling the air cleaner to access the port while yet another spot is under the oil fill. If all else fails, you may have to run the lines to find it.
I should have mentioned the place to add R-134 recharge. But you are correct the Low Pressure A/C port IS just above the engine battery. Fairly easy to add A/C Pro recharge if needed. Thanks for taking the time to help to locate the LP A/C Port.
The first thing is to connect the hose and see what the pressure gauge reading is.
Apologize for the misleading assumption. I really don't think I will have to replace the refrigeration/cooling unit at this time.:) Thanks again! KK
Happy to help! :)
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
