- StirCrazyModerator
if you know the brand/model of the fridge that helps a lot, if you just changed the bottles and it is a dometic then they flash green when in auto and trying to run on propane with no power and it failed to light, a simple restart might fix it.. if it is blinking in a patteren and/or its a different brand it could mean a totaly different thing.
- naturistNomad II
Given that it takes time to flush the gas lines of air, it is likely you just need to turn off then back on a few times to get the gas to the burner.
