John_Wayne
Mar 17, 2014Explorer II
The refrig. has a drain tube on the back is yours running out the out side vent to drain the water out. Could it be draining inside the rear vent and getting the wood wet. If you add a 12volt muffin fan to the back of the refrig. blowing up over the coils it will help keep the refrig. cooler. You will have 12 volt for the fan right at the back of the refrig.
Having RV issues? Connect with others who have been in your shoes.24,352 PostsLatest Activity: Jan 21, 2026
