mginnetty's avatar
mginnetty
Refrigerator left running with doors open for 2 weeks !
Had kids playing in the RV when it was out in the driveway ready to be put into storage with the fridge/freezer doors propped open with door clips. I'm guessing one the kids was pushing buttons and turned on the fridge and I just noticed it now 2 weeks later :(
The fridge and freezer weren't cool at all and had about an inch of water pooled in the bottom and some in the trays on the door. I turned off the power and have cleaned up the water and hope that it doesn't need replacement.
Anyone have an experience with fridge problems like this ?
Thanks for the info.
-Mark...
  • Hi Everyone, thanks for the quick replies.
    I cleaned up the mess and connected the power earlier this morning and checked back in about 5 hours and it is working ! The freezer is ice cold and the fridge cooled right down.
    The answer some of the questions...
    The RV and fridge are level.
    no odor.
    It is an Absorption fridge that can run on power or propane. Unlike the fridge in my house it doesn't have a compressor.
  • pianotuna wrote:
    wopachop,
    Direction of travel 3%. (1/2 bubble)
    Driver to front seat passenger 5%. (less that 1 bubble)
    I hope that helps.
    Thanks for this PT. Had wondered how much slope front to back and side to side would be in the "OK" range. Just never remembered to ask....:C
  • Did that to myself once. Had water inside the refrigerator and on the floor of the trailer. Didn't do any damage.
    Clean up the mess and check, is it okay now?
  • wopachop,
    I hope that helps.
  • Let's say you're in the trailer looking at the fridge door. Which angle hurts it the most?
  • DrewE's avatar
    DrewE
    Explorer III
    The water that collected is good evidence that the fridge was working properly--the cooling unit caused it to condense and collect. (It also suggests that the drip pan or its drain tube may possibly not be arranged properly or might be plugged up, assuming your fridge has them.) I don't think you have anything to worry about.
    Incidentally, 3 degrees off of level is a quite obvious slope, around a 5% grade.
  • Use a solar system to keep your batteries charged. Unplug from shore power. Install a master switch and turn it off.
  • Unless you have a odor. Running with the doors open will not cause a problem. UNLESS as another stated, you stored the unit off level more than 3 to 5 degrees. Doug
  • Have you tried to turn it on and cool it now? What type?
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 11, 2026
