Ron3rd
Jun 09, 2014Explorer III
Will it run on electric? Will it run on propane? It makes a difference in tracking the problem down.
If it will not run on propane, did you disconnect your propane tanks to fill them? If so, did you purge the air from the lines? I will light the burners on the stove to get most of the air out and propane up to that area. This can take about a minute sometimes. Afterwords you need to re-start the fridge. Just a thought.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
