powellmj's avatar
powellmj
Explorer II
Sep 16, 2019
Refrigerator Outside Vents
I have a Wolfpack 325 pack 13. The cabinets over fridge held a lot of heat and the freezer was just ok. Noticed a wasp flying around the external vents and thought I better check for nest. Pulled the top vent cover and was surprised to see that the wall covering came up over the fridge heat dissipater and there was a board across the top blocking airflow (pictures explain better) anyway there was only about a 3 inch gap for the heat to exhaust. I made some modifications and Wow, the difference was immediate. The aux fan had even shut off before I had things cleaned up and back together. It's worth a look to pop off that top vent cover and check.
https://ibb.co/k5fgd1c
https://ibb.co/qyCLYhK
  • Hey jkwilson, which piece, top (finished piece of dark wood exposing gap at top of refrigerator) or bottom (splintered piece exposing fins)? OP cut out two different pieces. Are you saying he should have left both pieces alone?
  • Piece you cut out is supposed to be there on many refrigerators. Keeps the air flowing through the fins instead of straight out the vent.
  • Why did you remove the top baffle?
    You're only making things worse.
  • OK.......center section was never removed....intent was but got forgotten/missed etc
    Other issue is that WIDE OPEN SPACE on top of fridge.
    That is a DEAD AIR SPACE and will HOLD HEAT
    That area should be completely closed off and sealed ----right at the back edge of fridge (LIKE IT WAS in 1st pic)
  • What kind of slob did that work?
    My trailer had insulation blocking most of the air flow and there was no baffle at the top. It at least had the lower board installed correctly. This kind of work is par for the course.
    You still do not have the lower baffle installed correctly and there is no top baffle guiding warm air from the top edge of the frige cabinet to the top of the outside vent. See the installation manual and do it right. While it works better now, it may not keep after under extreme conditions. Fridges installed in slides and utilizing side vents need all the help they can get.
  • Good catch. Just goes to show not everyone takes pride in their work.
  • Can’t see your pictures, but most refrigerators require that extended wall to keep the air from short cutting and not flowing through all of the piping.
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 25, 2025
