I did see this in the manual but took it to mean it might be more difficult to get it light at higher elevations, not that it would not work at higher elevations. I have had other Dometic fridges and never had problems with them at these elevations. If this model is meant to be used only at altitudes of less than 3300 ft them it makes it almost worthless for use in an RV.
It did not give any error code, only the "GAS" LED flashed and the fridge beeped.
Any idea if a different gas regulator would improve its operation at higher elevations?
Thanks,
Mike
