dpgllg's avatar
dpgllg
Refrigerator Upgrades
Hello,
I'm sitting here contemplating what upgrades I want to do to my 5th wheel once I pull it out of the underground storage facility in the spring.
The frig is in a slide out and from what I have read you should boost the ventilation for this setup
Frig Fan
I am considering adding this fan and also the baffle pictured.
Is this a good idea? Is it enough?
I just want to have all parts ready when spring finally gets here. Seems a long way off as it is only 7 degrees here right now.
Thanks
Dave
  • “No it is a brand new unit we purchased last June. The frig works fine.”
    Then why?
  • What is BRAND/MODEL of your fridge?
    Installation clearances are critical to good airflow which determine how well fridge can function and maintain cold in high ambient temps
    Top/side/bottom clearances should be ZERO (0") between fridge and compartment and need to be completely sealed
    Backside clearance (between rv outside wall and back of fridge) should be no more then 1"
    If clearance is more...then baffles may be required to direct airflow up thru absorber tubing and then across condenser fins at top.
    No dead air space at top either.
    Fans help when fridge is installed in a slideout due to lack of natural draft that occurs with roof top venting.
    Airflow thru lower side wall vent and out top side wall vent is NOT ideal so addition of fans is good
  • After my refrigerator died, I replaced the cooling unit with an Amish built cooling unit. While I was in in there I added two 4 inch muffin fans at the top of the vent with a switch, and adjustable thermistor by dometic. Also added internal fridge fans that mount to the fins in the fridge.
    I live in Phoenix, in the summer it’s 118 degrees and my fridge is 34.
  • Ivylog's avatar
    Ivylog
    Explorer III
    If it's a NoCold 12XX it needs all the help it can get...extra fan and no dead airspace at the top.
  • Fans and baffles are used to correct bad installations. If it was installed correctly by the RV manufacturer you won't need to do anything.
  • No it is a brand new unit we purchased last June. The frig works fine.
    I had to replace the cooling unit in my old 5th wheel and it was a pain. I just want to make sure this frig lasts with no issues
    I've never needed to do that.
Having RV issues? Connect with others who have been in your shoes.24,311 PostsLatest Activity: Sep 06, 2025
