enblethen
Jul 23, 2013Nomad
Check to see if you have 120 volts AC coming out of the circuit board. Check where the element connects.
It could be a bad relay on circuit board.
Make sure fuse on circuit board is good.
Make sure you are getting 120 volts AC at the recpetacle.
