AnEv942
Jul 30, 2013Nomad
If you do not have power at terminal j6 & 7 board is suspect BUT-
that would be the last link in the chain of events that should be tested. It could be several things before that and should be verified, namely fuses, fridge eyebrow board etc. There should be a 5 amp fuse for the AC side on the board. IF you correctly identified your fridge Norcold 6062-there is a good troubleshooting step by step. Also has pic of fuse location.
http://bryantrv.com/docs2/docs/600.pdf
Other than guessing and replacing parts- Without testing it can not be predetemined what is at fault.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
