AnEv942
Jul 30, 2013Nomad
Think Chris nailed it.
Id be also checking grounds judging by amount of corrosion on screws. Yes does look like a cover over fuse location. Obviously unplug before checking
edit-is the resister you mentioned earlier Chris the horizontal one to left of fuse? which looks ok in pic. The "burnt" end op mentioned cover on the fuse? indicating heat-possibly also corrosion?
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
