D_Sluv2fishandc
Aug 01, 2013Explorer
Posted By: enblethen on 08/01/13 08:44pm
I see come corrosion on the mounting grounding screw near J2. You may want to clean up this. It could be a poor ground not allowing the circuit board to work properly.
Other then that it is new board ttime.
Get model and serial number. If it is a Dinosaur board call them for assistance.
I was thinking about that too. Do you think it really matters for 110? I think I will replace the screw and clean off the corrosion on the board under the screw head and try it anyway.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
