YC_1
Jul 31, 2018Nomad
Great advice:
Fans must be working. Remove the upper outside panel and look inside. If you can't peek down then use a camera to see if there are some fans. There should be a snap thermistor that controls them. You might be able to trace the wires down to find it. A simple alligator clip will bypass it for testing.
The other thing is the vent tubes. If they are cracked they let in warm air. If you need to replace them you might be able to slide the refer forward just a bit after finding all the hidden screws holding it in place. Front and back of course.
