dougrainer
Aug 01, 2018Nomad
You can run the refer 24 hours longer with the 120 elements hot wired. You have verified it is not a cooling unit failure/leak. You can have a defective Thermister. Defective Thermister's will test(ohm) out correctly. The ONLY way to verify a bad Thermister is to replace it. The defective Thermister will indeed cause short cycling, but will also shut the LP on and OFF also. Doug
